M
MikeF00
Hello, i recently rerouted some plastic overflow pipes from both header tanks in my attic to the outside through an external wall. When i came to test them for leaks (by holding down the ball float) and trying to allow water to flow down the newly rerouted pipes , nothing happened and water did not flow down the pipes? Is this due to some weird air pressure trap(think its called hydrostatic pressure) in the pipe work?. This wasn't a problem when the pipe was routed the other way.
The overflow pipe in the tank(s) does have a 90 deg elbow on it and points directly into the water. Although i have not changed this from last time. Both tanks have the same configuration in them
Any suggestions?
Any suggestions?
