View the thread, titled "Pump control to thermostat wiring" which is posted in Water Underfloor Heating Advice on UK Plumbers Forums.
Hi
Installing single zone ufl with Grundfos pump/mixing valve and heatmiser thermostat - not crystal clear from the diagrams how the control connection to LR/LS should be wired (i.e. red on the pump control diagram)
Any advice much appreciated!
It states on the instrucions, that LS/LR (A1 and A2) go to the boiler? Are you wiring it differently?
At a guess I’d say the wiring must connect back to the boiler to operate the heating independently, or possibly using a motorised valve.
Looking at the instructions, if you’re replacing a radiator, the ufh is controlled via a trv, not a room stat. The other option mentions a zone valve (motor valve).
Hi jbatexning
If you are just asking about the connections between the stat and the supplied junction box:
(obviously you provide wiring from the fused spur as illustrated bottom right, and then🙂
Blue (N) to stat terminal (N) !
Black (L) to stat terminal (L) and link to stat terminal (A2)
Red (SL) to stat terminal (A1)
Grn/yel (E) insulate safely at stat, unless there is a E terminal in the stat, in which case connect it there!
If you buy 3 core plus earth cable to connect the stat, it will likely be: Brown, Grey, Black & bare copper (in cable), or green/yellow (flex)
In which case typical use of these colours is
Brown - permanent live
Black - switched live (put a brown sleeve on it)
Grey - neutral (put a blue sleeve on it)
green/yel - earth of course.
ChrisB1982 - It is option 2 that I am installing (own pump, blending valve, and room stat)
Basher – it was the A1 and A2 connections I was unsure about, and understand now :
live link L to A2, and red LS to A1
Many thanks for your help!
Reply to the thread, titled "Pump control to thermostat wiring" which is posted in Water Underfloor Heating Advice on Electricians Forums.
