Pump installation
View the thread, titled "Pump installation" which is posted in Central Heating Forum on UK Plumbers Forums.
Hi All
The 2 radiators in my front room don't heat as quickly as I'd like. Probably because they're the furthest from the boiler which is upstairs in the bathroom. Would it be good practice to install a pump of some kind on the flow and fix it under the stairs or is this a ridiculous Idea?
Hi All
It's really difficult to give good advice without knowing a little more about your system, size of house, how many radiator's etc but in general you wouldn't fit a secondary pump to a domestic heating system. My advice would be to balance the system and see what effect that has. It's easy to do but quite time consuming so it will save you some money if you can do it yourself. There are lots are videos on Youtube which will help you. Hope this helps!
Reply to the thread, titled "Pump installation" which is posted in Central Heating Forum on Plumbers Forums.
dwalsh1,
Marcus Ward,
