View the thread, titled "Pump noise" which is posted in UK Plumbers Forums on UK Plumbers Forums.
W
wally5460
A friend of mine had a new circulating pump fitted to their central heating system. the pump is very noisy when running, makes a fairly high pitched whining? Can anyone suggest the reason for this noise?
Hi Wally, check the following with regard to the pump.
Has it been fitted the correct way round,
Have both of the pump valves been opened fully,
Has the pump been bled of air.
The whining sounds as though it may not have any water in it. Also check the correct speed has been set on the pump.
I got called to a similar problem whilst plumbing in Glastonbury and found that the customer had fitted his own pump and had not opened one of the pump valves.
Hope this helps.
Regards,
Graham
[DLMURL]http://www.Plumbfixit.synthasite.com[/DLMURL]
Thanks for the advice Graham, coincidently im from street just down the road from you. Im currently studying for my City and guilds 6129 and hopefully will complete my nvq2 also. Ive been in engineering since leaving school and am looking for a career change so am using this forum for advice along the way to completing my qualifications.
Reply to the thread, titled "Pump noise" which is posted in UK Plumbers Forums on Plumbers Forums.
