pipemajor
Hi all, I'm new to this forum, but I hope someone can help me.
A few days ago I turned my central heating on as it was getting a bit chilly in the evening. After about half an hour I noticed my radiators were still cold. I checked the boiler and the pump wasn't spinning, but the body of the pump was very hot.
I removed the central screw and the pump was easy to turn with a screwdriver.
When the pump was powered on I can hear a slight buzzing coming from the motor, and it gets hot, but if I try to spin it with a screwdriver it doesn't start. I took the cover off the capacitor and found it appeared to be leaking as there was a clear liquid in the housing. I stuck a multimeter on the mains terminals and got a reading of 210 ohms.
I changed the scale to millivolts range and spun the shaft and got a reading.
This would suggest to me that the start capacitor is stuffed, but I thought that if I spun the motor it would continue to turn, so I'm not sure if it is the capacitor or that the motor is u/s. I would be very grateful for any suggestions and advice.
