SteveMFF
Hey All,
So my tenants have been having issues with the boiler for the last month or two now. I've had a heating engineer out who has tried all kinds of things but we still have no solution. I believe we have narrowed it down to either a blockage in the pipes or the pump has issues. He's tried various things for both but no joy. Obviously if it's the pipes it's a much bigger headache so I'm hoping someone here has some ideas for experiments we could try to isolate the cause before I buy a pump only to discover its the pipes or take up all my floors only to discover it was the pump!
Here's the flat details and some of the things we've tried...
- Jaguar 28KW Combi boiler (from reading on here I see buying this may have been my first mistake :biggrin5🙂
- Small ground floor flat with boiler in the kitchen - 5 small rads and one large rad in total.
- Remote thermostat in lounge that triggers the boiler in the kitchen (seems to work fine)
- I have always had to top the boiler up a little more ofter than normal (maybe once every few weeks or once a month in the winter when it's in daily use) to keep the pressure correct so there may be a small leak somewhere but I lived there for several years and never noticed any evidence of leaks in the system or any additional issues. Still it's a possibility.
In essence the issue you see is the boiler firing up as it should and the water quickly reaches the prescribed temp but then it switches off and doesn't come back on so you get a short burst hot water to the rads but no more and they never really heat up properly. If you set different tempretures it turns off at the appropriate point (6 or 7 degrees past - so if it's set to 65 I see the boiler click off at 70ish) so I think the thermostat is OK
The first thing he changed was the plate heat exchanger as he thought this was probably scaled up and causing the issue. He also looked at the obvious culprit, the pump, but he says it seems to work OK, he then got a pressure jet to flush any blockages out of the pipes but, again, it doesn't seem to have really helped. At the moment he's left it with some balancing of the valves to try to even out the small amount of heat getting through the rads but is stumped what to try.
OK so here's the thing, I know from my fathers (oil) boiler that just because the pump seems to be working doesn't always mean that it really is. I don't know how the HE tested it but I assume he had the right tools but can anyone think of some tests that we could run on the system to isolate if the issue is pump or pipes? or perhaps there is something else we've overlooked as a cause?
I don't mind paying the ££'s to fix this but I want to be reasonably sure I know the culprit before I start ripping up floors.
Apologies if I got some of the terminology wrong, I'm learning about heating systems as I go here :biggrin5:
