Pump running continuously
View the thread, titled "Pump running continuously" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
johnf7162
Can anyone help. I have a Baxi Genesis 80 combi that is misbehaving. On HW everything is fine. On HW/CH everything works as it should but the danfoss pump is running continuously. There is no room thermostat. with the CH control knob turned to minimum and no demand for HW the pump continues to run. Could it be a flow switch or PCB. The manual shows a "safety thermostat" clipped to the pipe at the 3 way valve - is this used to determine whether overrun should be switched off. Thanks.
John
You require a gas safe engineer. This forum no longer provides boiler repair advice on the open forum.
Reply to the thread, titled "Pump running continuously" which is posted in UK Plumbers Forums on Plumbers Forums.
johnf7162,
Rickster123,
