SHBS
I am about to install the drains for a mill conversion and as they will run under the concrete floor I would like to use solvent weld fittings for a more permanent job. However, I can only find a push fit rest bend for the bottom of the stack. This makes me think that solvent weld is usually only used above ground and push fit underground. Is that the case?
Stuart
Stuart
