plumbingdazman
hi everyone i need to tee into some hep2o plastic to run 2 cold feeds and a hot feed off the pipes in the basement and then out of the remaining connection run some copper through the floor to the taps and toilet.
What i want to know is can i tee into hep2o using jg speedfit?
Are pushfit fittings pretty much universal and inter usuable with other brands as the place i can get to does not have hep2o fittings.
and are the pipe inserts all pretty much the same size regardless of make
Its 15mm i, teeing into
Also will this item on toolstation item number 20255 its a tct core drill 110mm drill through concrete ok as it says it will do but not sure as does not say diamond tipped and my local tool hire wants 30 quid for the day to hire there drill and core bits.
Many thanks
Many thanks
