View the thread, titled "push on pipe from CW Tap to HW Tap for airlocks...where can I buy/what do you use?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
W
wet wet wet
Looking to update my bathroom but worried about the possibility of air locks. I am looking for the old fashioned push on washing machine pipes that used to go on your taps so that I can blow the air lock out from cold water through to hot water taps. So far I have not been able to find anything like these anymore. Any advise on where I can buy or how to adapt would be appreciated.Thank you...wet wet wet
Re: push on pipe from CW Tap to HW Tap for airlocks...where can I buy/what do you use
if your going on to the washing machine valves just use the washing machine hose, will do the job no problem.
poundland possibly or just use a bike innertube and 2 cableties
Hozelock do a range of tap fitting attachment`s you could adapt also Wilkinsons do a similar selection bit cheaper regards turnpin:willy_nilly:
I think your paranoid about air locks or is it a fetish.....
2 of them connected to a short piece of hosepipe will do the trick! also come in handy if you want a hosepipe outide a house and no outside tap for something , cutting tiles or mixing cement or something ......... as you do 😛 !!
I prefer to use my wet vac.
Reply to the thread, titled "push on pipe from CW Tap to HW Tap for airlocks...where can I buy/what do you use?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
