View the thread, titled "Question about installing a wood boiler stove" which is posted in Boiler Advice Forum on UK Plumbers Forums.
The thermal stores have an overheat protection and will discharge water to drain in order to lower the temperature, unvented cylinders do not and cannot control the temp from solid fuel although they are a far better system and not so prone to limescale build up as thermal stores. However thermal stores can be connected to a gas boiler, solar, electrical heating and solid fuel or all four at once.
Steve
Steve
spot on steve from what i know of thermal stores.
back to the back boilers...our systems seem to work perfectly with the addition of blow off pressure and temp. maybe its technically incorrect but i have not made this up myself only learned it from the company i work for.the boss is a mechanical engineer with 40 yrs plumbing experience.apparently he is very highly regarded in ireland.one of the first registered solar,heatpump,air con installers in the republic as they came on line over the years.i value your comments .things are more strict in the uk as regards regs.we are a tad behind on the paper work stuff.i can only vouch for work i have done and seen done from personnal experience.
solar heat is controlled, it has or should have a pump and by pass incorporated on the pipework between panels and cylinder, operated by the controller and pipe stats.
shaun
shaun
did u post this on wrong thread.what are u talking about here.😀
the stove will have an amount of water in it,the relief valve should be as close as possible,in case the circs comming of it are isolated or blocked.
without the relief valve the stove would super heat the water, resulting in the stove exploding throwing red hot , water and steam over every one in the room, if you were lucky to miss the water the burning wood and the embers would ignite what was left of the room and its hysterical occupants. picking white hot cast iron off their burned scalded bodies
if you dont know don't do
lee i am beginning to consider my part in the death of some poor unfortunate as a result of this job.
lennox. i stated already that even experienced plumbers would have difficulty with such an installation.i am only fortunate to work alot on this type of thing and thats why i tried to help.if u are going ahead with this u need to post drawing of what u are going to do exactly. p.s can u leave the b boiler open vented altogether.
sorry lenox, but youve asked the same question on different threads, you dont know what you are doing judging by your answers, and its not a case of being rude, i would love to help you, but you need some basic fundamentalist knowledge in not killing people. i wont post to you anymore, sent you a private message explaining what could happen. google it, then you can blame google when you do vaporise some womans head off.
At the end of the day, this is a website for burying our own super plumber ego, and for helping and advice, both giving and recieving.
sometimes the best help is no help !!
shaun
Hi Buffy, thanks for the advise you have gave to me. I have made a drawing for my proposed installation can I e.mail it to you for your coments.
regards
lennox
Reply to the thread, titled "Question about installing a wood boiler stove" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
lennox,
lennox,
