T
Tap dancer
I know that inhibitor was put into my CH system some time ago, but I've no idea what make it was and whether it was enough, and whether it has a limited lifespan.
I would be grateful for anwers to these questions (just quote the number of the Q).
1. Would it be a good idea to add some more?
2. Is it OK to mix the new one with whatever the old one was?
3. Can you do any harm by adding too much?
4. Can it be added by shutting off one rad at both valves, removing the bleed valve assembly, and pouring it into the hole using a funnel and flexible pipe?
5. Should it be topped up from time to time because it has a limited lifespan (in the same way that I have to add a chemical to my water bed every 6 months to condition the inside of the vinyl).
