hard to describe but here goes,
my boss has just fitted a boiler room and now gone on holiday leaving me with a few little bits to do
1st there is an expansion vessel fitted but he hasn't run the pipe work for the pressure relief valve yet, so I am left with the 3 bar relief valve with a short pipe of half inch coming out of it, i need to work this round to the corner of the room where i have brought a 1' 1/2 waste pipe up, to take condensate, this blow off and another blow of from the unvented cylinder.....
it will b very hard to fit a tun dish off the pressure relief valve as the vessel is sat on the floor, so too low to get your 300mm before the first bend, is it essential to fit tun dish on here? also can this pipe connect into the blow off from my cylinder, which is in 3/4 with a Tun dish,
if you can imagine, my waste pipe comes up on an elbow, then goes vertically up about 3 inches, then has a tee, which is facing so the brach off the tee picks up the condensate and i wanted to fit a 22mm reducing tee above the top of the waste tee and drop my blow off into it
very hard to explain but with my boss being away im not sure where else to turn for advice!!
THANKS FOR READING!1
