View the thread, titled "R40 damper problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
cm3luc
I have a Riello R40, i replaced the control box as it was playing up (stop startin, not firing up) .
However,now with the new CB, when she is on prepurge, the damper is not opening up the air flap, tho when there is ignition it opens up no problems- is there any reason for this? i tried another pump but it was exactly the same
I was wandering, can i just take the flap off?
Also, what is the difference between a R40 pump and a RDB pump, is it just the side mounting bolts for the copper oil pipes? if i switched these bolts over is there any issues?
Reply to the thread, titled "R40 damper problem" which is posted in UK Plumbers Forums on Plumbers Forums.
