View the thread, titled "Radiator not working" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
T
T & H Plumbing
Hi sorry if im posting in wrong section but im stuck
i currently have my central heating on, and all the rads are working perfectly apart from one upstairs in the bedroom, it will not turn on i have tried
ive tried bleeding the rad, it bled correctly ive also turned the rads on using the TRV but still the rad doesnt heat up
i have noticed the coper pipe connecting the rads arnt even warm, i thought the piped leeding to the rads before the TRV would be warm
could anyone help in my matter? and give me some pointers thanks
You system could need balancing, have you tried shutting the other rads on the system down and see if it pushes the heat round to that rad, it could be the other rads are stealing the heat.
Also check the lockshield valve (the one that isnt the trv) and check its open enough
Yeah take head off, turn it upside down and use it to push pin in and out a dozen times. Trv might be having bad hair day.
right before i posted this i did remove the TRV and put it back on, i am now doing as instructed and turning all rads off ill get back with any news
BOOM 🙂 Turned them all off then burnt my hand on his rad haha, right so now i guess i have to open the others slowly and get them all on at the same time yeah?
Just a balancing exercise now.............. Ahem............ Time for Croppie's handy cut 'n' paste!
How To Balance Radiators
Tool List:
Radiator-bleeding key
Lockshield valve adjuster or adjustable spanner
Screwdriver
Digital thermometer or multimeter with thermometer function
1. Make sure all the radiators have been bled. Turn off the central heating and allow the radiators to cool.
2. Familiarise yourself with the valves. The lockshield will usually have a push-on cap or one that is secured with a screw through the top. Remove it.
3. Older models will have a wheelhead valve on the other side — used to turn the radiator on/off.
4. Newer radiators will have a thermostatic valve instead of a wheelhead valve.
5. Open up the valves on all the radiators in the house by turning them anti-clockwise.Wheelhead and thermostatic valves can be turned easily by hand, but the lockshield will need a plastic adjuster to open it up. These come with new lockshield valves. A spanner will also do the job.
6. Turn the central heating back on and note down the order the radiators heat up. Those nearest the boiler normally get hot first. If you’ve got a lot of radiators, get assistance. Turn the heating off and wait while the radiators cool down.
7. When the radiators are cool, switch the heating back on and go to the first radiator on your list. Turn the lockshield valve clockwise until it is closed and then open it by a quarter of a turn. Once the radiator has warmed up, take a temperature reading at the pipework leading to one of the valves.
8. Now take a temperature reading at the pipework leading to the other valve and open the lockshield valve gradually until there’s a 12°C difference between now and the reading you took in step 7 (allow a couple of minutes after each adjustment for the temperature to change). The temperature figures indicated in the last step and this one are relevant to the radiator shown – don’t take them as any kind of optimum figure – it’s the 12°C difference in temperature at the valves that counts. Next, check the rest of the radiators in the system following the order in the list. The further you move away from the boiler, you’ll find the lockshield valve will have to be opened more. The last radiator may need to have the lockshield valve fully open to work at full efficiency. Your radiators are now balanced and should work perfectly.
Getting A Temperature
A key part of this job is measuring the temperature difference across each radiator. Specially designed thermometers that strap round the pipes at either end of the radiator are available to buy or hire, but it’s not really necessary to use these. You can get away with a single digital thermometer — it just means that you can’t take simultaneous readings and you’ll have to move from one end of the radiator to the other.
Digital thermometers are available from around £10. Alternatively, some digital multimeters have a temperature sensor function. A digital multimeter with temperature function costs from £25 and can also be used for taking electrical readings and checking continuity in wires, among dozens of other functions.
.....so take me through that again?
Tool List:
Screwdriver
i have just started my NVQ lvl 2 plumbing n heating at college, i guess i will be using this forum alot 🙂
thanks for all your help guys, i had an idea to turn them all off but wasnt sure hence i came here
thanks for the tips on balancing my rads, i will do all that in morning
Before collage ??? Keen?
Van will be out side at 06.45 it's yours along with job! Most apprentices cant manage 8am start when level 2!!
Reply to the thread, titled "Radiator not working" which is posted in Gaining Plumbing Experience on Plumbers Forums.
