View the thread, titled "Radiator Reflectors ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
matt222
What are peoples thoughts on this foil-faced bubble wrap that is designed to be stuck to the wall behind a radiator to reflect heat back at it - do we think it actually makes any difference ?
They definitely work. Try and get hold of a thermal camera and have a look. Or get an IR thermometer and point it at the outside wall where rad is and then where there is no rad even if you use Baco foil you can notice the difference. The thermal insulation is better still
Reply to the thread, titled "Radiator Reflectors ?" which is posted in UK Plumbers Forums on Plumbers Forums.
