Radiator valves question
View the thread, titled "Radiator valves question" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi guys, got supplied some corner valves but they have a rubber to go into the radiator inlet to create a seal.
Well I imagine that's the idea, fit hundreds of valves but always used Ptfe or Loctite. Never actually seen one like this.
Will the rubber do the job, or should I remove and fit as normal with Loctite?
Any advice be appreciated
Rubber should be good a lot of rad blanks and bleeds use a rubber seal now don’t forget they are parallel threads, will look neater without ptfe showing. You can always use loctite fluid if you don’t trust it
Great thank you, i have some rapid blue so maybe a smear of that and let it set and leave the rubber on ?
Reply to the thread, titled "Radiator valves question" which is posted in UK Plumbers Forums on Plumbers Forums.
Zach054,
Zach054,
