Hi, Since having some house renovations 2 years ago, which included adding two extra rads, replacing others and re-plumbing the boiler , I have suffered from quite loud, (but variable) 'water flowing' hissing noise, which is especially noticable from the first two rads on the system (which happen to be thin tall vertical types (Milano Alpha doubles), see below).
The noise is loud enough to be distracting over a TV and - short of posting a clip - I can describe it as the sound of water constantly rushing thorugh a pipe!
For several years I've tried all sorts of advice from plumbers and even the rad manufacturers, but to no avail and am my wits end!
The boiler is a Greenstar 30CDi condensing type. Things we have tried include:
- Checking the valves are all fitted the right way round. The arrows show they are bi-directional
- Bleeding all the rads, in various orders, including banging the outside of them to get any trapped air out. I'm pretty confident there isn't any as water runs freely from the bleed valves.
- Taking TRVs off and pumping the pins up and down. We use E-TRVs usually, but the noise is the same whether they are fully open or mostly closed, with or without the TRV heads on.
- Adjusting the lockshields. Yes, we had trouble balancing the sytem at first, but a plumber helped do this so the new rads all get hot. this didn't seem to make much difference (maybe a little) to the noise
- We have one rad on the system fully open
- The pressure in the system has suffered from drops over time, which suggested a leak and likely air noise, but this was traced to the internal expansion vessel needing to be pumped up; in the 3 weeks since this was done, the pressure has been reasonably stable at 1.4-1.5 bar (indicated on front of boiler).
- when the boiler was re-plumbed, a lot of pipe bends were added on the CH flow which now has about 5x90 degree and 2x180 degree bends in the first metre or so of pipe. Could this degree of bending be somehow leading to greater noise on the first rads? (see pics below)
- Inhibitor was added to the system after installing; someone recently suggested I could try a 'noise reducing additive' Could this be a solution; I don't really understand how this might work.
- Would replacing the thin designer rads with more traditional ('rounder') rads potentially solve? They were expensive and would involve draining down, so only really considering this as a last resort.
