View the thread, titled "radiators downstair cold, upstairs red hot" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
J
jarvis0808
hi please help
worcester condenser boiler fitted, pressure was 2.5 so i drain all system off using pressure relief valve. Re filled and topped up to 1.2 but radiators up stairs red hot but downstairs cold, what have i done wrong
rachael
how should i have released too much pressure then??
hi thanks for quick reply, would that mean it would drip through pipe on outside then, and if so do i need to replace prv seals (how many are there ?)
Try and see if there is a drain cock on any of the rads downstairs or under the floorboards and simply drian some water out of it to relieve pressure. Turn all the valves on lockshield aswell and bleed with bleed key on every rad repeat and re pressurise.
Reply to the thread, titled "radiators downstair cold, upstairs red hot" which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
