View the thread, titled "Radiators hot upstairs and cold downstairs." which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
M
martinryder
I know this has been asked before but in different curcumstances
This is a sealed system (pressurised) sytem boiler Glowworm Ultracom about 5 years old. The filling loop failed and it over pressurised and blew off about 3 bar. That fixed the doorstairs rads are stone cold. Upstairs are OK and heat up with 2 mins. The boiler is located downstairs.
I've drained it down serveral times and added F3 cleaner without any joy.
Before I get the expense of a powerflusher can anyone suggest what it make be causing this ?
Many thanks in advance
turn the upstairs rads off and do you get any heat downstairs?
whats the water condition?
could be a problem with the pump?
tried turning off upstairs using TRVs. Still cold down. As I've drained and refilled several times the water is clear as a mountain stream. As the upstairs get hot within a minute can this be a pump problem in the boiler ??
Is this your own system or a customer?
Is there a zone valve for up and down?
With the upstairs turned off does the boiler cycle on and off quicker than it does with all rads on?
Its mine. No zone valves. The boiler does cycle on/off quickly after reaching 82. I will try the locksheilds as well. How can I free a air lock?. Bleed all rads upstairs
Turn the rad above the drop off, with pump running occasionally put the speed selector switch between settings to stop the pump, flick it on and off several times
Not sure if that can be done with a pump inside the boiler. Can you explain the term tuen the rad and drop off. Sorry but I'm not an plumber
So you'll trust all the plumbers on the Internet, but can't be bothered to find a good one local to you? Get real dude. False economy to try and fix yourself
Reply to the thread, titled "Radiators hot upstairs and cold downstairs." which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
