T
tazmac
When the heating comes on/goes off, I have an awful noise coming through the pipes to the radiator predominately in the bedroom as if someone is tapping on them Any adeas as to how to stop this noise??😕
Hi. Expansion and contraction are likely causes. As has been suggested check the pipes running to the rad they may be tight against joists or the hole up through the floor may be stopping any natural movement. Good Luck[/quote
ill second that tight fitting laminates are often the cause of this or pipe work to tight in the joists
Reply to the thread, titled "Radiators knocking" which is posted in UK Plumbers Forums on Plumbers Forums.
