rain water to soil ?
View the thread, titled "rain water to soil ?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
T
tenor
Is it allowed to run the rain goods down spout into the soil/vent stack of a single stack system ? If so , at what height relative to the toilet and bath wastes . Thanks for any help.
hi, check to see if you have mixed foul and surface drainage at the property. if you have then no problem . if you have seperates, a little rain water in the foul will be ok . but not vice verser . 😉
There whole housing estates built in the 60,s which discharge rain water into the sewer. The water company now charge the householder for the privelage
the soil stack acts as a vent pipe,taking smells above your roof, you may end up with sewer smells comming out of your guttering at points you dont want,
thanks for your replies. House is 1928 semi. rain goods lead into regular gullies which discharge into soil pipe/ sewer pipe underground. I take the point about gutter smells as we have a single floor extension at the rear. About the upper level, how far would any vent have to be above the eaves line and how far from any opening window. Bearing in mind , the whole idea behind this is purely aesthetic.
Hi. If you have a combined system, make sure the RWP. enters a trapped gully prior to entering the drains. Vent pipe needs to be 1m above any opening into the building and or 3m away on the horizontal. Good Luck
i was told at college a few years ago under some circumstances you can run surface water into foul water if its at the end of the run . think it has to be oked by building control befor tho.
Reply to the thread, titled "rain water to soil ?" which is posted in Boiler Advice Forum on Plumbers Forums.
tenor,
feltham,
