View the thread, titled "rattling pipes" which is posted in UK Plumbers Forums on UK Plumbers Forums.
poynton phil
Hi just popped over from the tiling forum to see if anyone can help me out with a problem we have at home, we've just had our kitchen extended and the pllumber came took out the old sink and waterpipes, then extended them up the wall across the new ceiling beam down the opposite wall, so to feed the fridge with water for the ice maker, then across the floor to the centre island. The problem is that when we run the hot taps the pipes start rattling like crazy, the plumber said it is just trapped air and with go in time, but after a couple of months of this its still driving us mad, just wondered if what the plumber said was right, and that it will right it self. any advice will be appreciated.
Has he clipped the pipes correctly?
15mm copper pipe clipped horizontally about every 1.2 metres. Vertically, every 1.8 metres.
22mm copper pipe clipped horizontally about every 1.8 metres. Vertically, every 2.4 metres
or has he used plastic?
plasic 15mm horizontal clipping should be every 0.6 metres andvertically, every 1.2 metres.
22mm plastic pipe should be clipped every 0.7 metres horizontally and every 1.4 metres vertically.
Welcome from the tiling forum.
As Nick has mentioned the pipes should have benn clipped as listed. There should also have been sufficient space left between the pipes and any other obstructions they are passing over ie. the new ceiling beam.
If you have 1/4 turn taps fitted it may not be helping with the pipe banging. As they turn off so quickly they do have a tendency to make pipes bang if the pipes weren't clipped properly in the first place.
Mark.
Reply to the thread, titled "rattling pipes" which is posted in UK Plumbers Forums on Plumbers Forums.
