View the thread, titled "Ravenheat combi , luke warm water" which is posted in Bathroom Advice on UK Plumbers Forums.
M
makumgav
Hi All, hope some one can help before the snow falls .....
i have a Ravenheat combi not sure of the model , looked all over it but no numbers etc, its about 7/8 yrs old and all of a sudden the water is intermittently hot then cold ,te CH s fine, i can run the water one day and its red hot next freezing cold ....
i turned the water control right up tonight and turned the CH off and i got hot water , the boiler gas flares up when i turn the water on but its still luke warm, the water is primed at 2b, if i run the tap slow it makes no difference, i cannot find any summer/winter switch which iv read about, any ideas
Cheers Gav
Hi Gav & :welcome:
Sounds like obvious issues with hot water temp control🙂 Alas not necessarily a straight forward remedy!
Could be simple as a sensor or as complex as flow restrictions... Best bet is to get someone to have a look at it B4 it fails all together :IMO
Post a request on the "In need a plumber/gas engineer" Forum with some basic area and look out for a PM 🙂
You could have thermistor,heat exchanger ..problem. Same advice as diamondgas, you can't do anything, you need engineer to look at it. Post a request and anywhere close will answer.
thanks for that lads , doesn't sound like a quick fix , got a lad in the village who works on combis etc , will just ask him to take a look ,
thanks again and will post the remedy when sorted , Cheers Gav
Reply to the thread, titled "Ravenheat combi , luke warm water" which is posted in Bathroom Advice on Plumbers Forums.
