F
FusionIP
Would anyone be so kind as to give a rough range of reasonable cost for re-piping work? First quote seems pricey. (North of England).
In a nutshell:
Unfindable leak in concrete in downstairs CH circuit. We therefore have five rads that need to be repiped from above.
They are all either directly or very nearly below an upstairs rad, with only carpet and floorboard/flooring board to lift, so pretty straightforward access to flow and return.
Three of the five will need to have the new pipes chased into the wall. The other two can have surface mounted pipework.
System is 1970s 'normal' bore copper, although we've no fundamental objection to the new work using push fit if cheaper/quicker.
We understand tat the final cost can be affected by numerous issues (including who does the chasing out of the wall and the cost of re-plastering) but a starting point would be helpful. Thanks in advance.
In a nutshell:
