View the thread, titled "Rear-flued boilers." which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
LPC
For a job I need a boiler with a rear-exit flue that is capable of going through a 1.2m thick wall with no joints.
Already ruled out Glowworm as their rear-exit boiler can only be used with a telescopic rear flue which is only ~600mm long.
Any ideas? The boiler cannot be lowered and there is no room to put another hole through the wall.
Daft question but why can't you have a join?
in a wall / cant get at it to see it my guess
and can you have a bend then rear as worcester do a long slinky flue
This is going to cause a lot of discussion.
How would you inspect a telescopic?
Plus is a 1.2metre thick wall a void?
I don't think it is, any other views.
Yeah, it's an interesting point.
Another point is if I put a joint in anyway, how would gas safe even begin to prove that there is a joint in the middle of a 1.2m thick wall that's totally mortared in......
I would like the job, but i'd rather find a way to do it without a join!
Just as a matter of interest what has a wall that thick.
They would know. by knowing what flueing options are available to buy. I cant think of a solution either.
Run the flue through some duct (6 inch soil pipe) with some form of inspection cover outside?
I've looked at a way of putting some kind of inspection hatch in but I don't think it's possible without major work. You can see the wall hole by removing the electric meter box (it's loose) but it would be difficult to get in there and make the join. It might count as inspectable though because you would be able to see it.
The main problem seems to be that no-one make a rear-flue long enough. You can't joint them to make them longer so if the wall is thicker than 600mm then there's no way to add on, joints or not.
Voters do a balcony model for external wall mount, then it's a matter of pipe work through the wall only
Nowhere to mount it outside. In fact the flue exits about 40cm above outside floor level!
You question having a joint, next question how to inspect the joint where the flue joins the boiler.
personally I think you need to check on the definition of a void, a 1.2m thick wall with a flue cemented in at both ends isnt really a void in my humble opinion
Reply to the thread, titled "Rear-flued boilers." which is posted in Boiler Advice Forum on Plumbers Forums.
