View the thread, titled "recommendation And advice are welcome." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Ron. I didn’t say that I knew how you worked. I also didn’t say that you was doing bad jobs or cutting corners or ripping people off. I did however ask you to stop using the wrong data sheets and to not miss inform customers. I say this as I wouldn’t want it coming back and biting you on the bottom later on, that’s all. I know I have upset you and I honestly didn’t mean to. I was just trying to prove my point.
https://www.vaillant.co.uk/downloads/ecotec-plus-937-spare-parts-manual-261488.pdf
Clearly states for model vih vl 15 s / 10liter each vessel ... that’s sold in uk. You can use the part number 0020039781 and you can get that online heating spares etc ...
You really did not upset me.. I like discussing matters which is totally normal. I just don’t believe I’m so wrong ... I can see I can get the storage on English markets with the part number which indicates that you misunderstands the vih cl 15s that’s just the name of the boiler. If you type in the part numbers you can see that the storage comes up with 10 litres each. A lot of Vaillant
Engineers haven’t got a clue if you talk with the, on the phone. Just 2 days ago I spoke with one guy and he wanted to tell me I would need 3 bar mains pressure and 20l flowrates to be able to install this boiler. I had to call a different guy and he told me it was total boll.... the point I want to make is that I strongly believe that it’s the same boiler like Germany with a slight difference in kw output. We have 20 and 26 which is well enough but here in uk is 38kw
Clearly states for model vih vl 15 s / 10liter each vessel . that’s sold in uk. You can use the part number 0020039781 and you can get that online heating spares etc .
Ron. I am not saying that your picture doesn’t say 10ltrs. It does what I am saying is it is wrong code VIH 15 CL S refers to the 15ltr store and code VIH 20 CL S refers to the 20 ltr store. You may be able to get the 20ltr in the uk. But it is not supposed to be fitted to the boiler. As per Manufacturers instructions it states that the boiler has a 15ltr store. In the world of gas and gas engineers mate MI’s are god.
You really did not upset me.. I like discussing matters which is totally normal. I just don’t believe I’m so wrong . I can see I can get the storage on English markets with the part number which indicates that you misunderstands the vih cl 15s that’s just the name of the boiler. If you type in the part numbers you can see that the storage comes up with 10 litres each. A lot of Vaillant
Engineers haven’t got a clue if you talk with the, on the phone. Just 2 days ago I spoke with one guy and he wanted to tell me I would need 3 bar mains pressure and 20l flowrates to be able to install this boiler. I had to call a different guy and he told me it was total boll.. the point I want to make is that I strongly believe that it’s the same boiler like Germany with a slight difference in kw output. We have 20 and 26 which is well enough but here in uk is 38kw
The boilers in Germany from what I have been told are a lot more Efficient.
Soooooooo true 🙂 plenty of different type of boilers.. but again we aren’t in Germany. I get what you are saying above so let’s put an end now ? 😛😀😛😉
Reply to the thread, titled "recommendation And advice are welcome." which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Old Account,
Old Account,
