Guest viewing limit reached
Recommendations for Vaillant combi heating controls...
View the thread, titled "Recommendations for Vaillant combi heating controls..." which is posted in Central Heating Forum on UK Plumbers Forums.
Jennie
Hi all,
I could do with recommendations for heating controls.
The customer is a small church/church hall - with a fairly new 30kw Vaillant Ecotec Pure. No heating controls (other than the inbuilt time clock) were fitted by the original installer. They've got two heating zones (currently operated with lever valves) for the main church, and the church hall. (Unfortunately the original installer has gone out of business, so they can't chase him to rectify it - benchmark was ticked off as having temperature controls).
But anyway, they'd like temperature controls for both parts of the building.
I've been looking at a couple of options:
1. Vaillant controls. Vaillant suggested their VRC 700F wireless programmer/receiver, with wiring centre VR70, and a second stat VR91 (only comes as wired, and I need wireless). Used weather compensator. As well as being very expensive, they also appear to somewhat complicated for the customer to use.
2. Salus controls. The IT500 gives two zones. Is used with a second stat, the IT300. It couldn't be more simple. Looks easy for the customer to use. And also a great price. But Salus have a terrible reputation for reliability.
Any suggestions for other options would be much appreciated.
To recap, two heating zones are needed. All to be wireless. And easy for the customer to use.
Thanks for your advice everyone,
Jennie
I tried to avoid for the longest time but Hive is a really nice simple control once set up.
(I do hate myself a little more now)
2x hive or a 2 channel Drayton wiser for smart
2x eph combi pack 4 programmable room stats
1x 2 Chanel programmer at the boiler and 2x wireless room thermostats
I’m guessing it’s a small church as the heating output of an 830 isn’t very high?
1. I have a very similar set up to your Vaillant option at home. It works well, but is an absolute pig to use. I'm seriously considering changing back to a Drayton Lifestyle programmer.
2. For your two zones, I'd personally go for a simple two channel programmer, Honeywell two port zone valves and Honeywell wireless thermostats.
Does the Drayton Lifestyle allow for two heating zones? Or any other programmer you'd recommend?
Hi everyone,
Thank you all so much for your recommendations.
I've looked through loads of controls this week, and like the look of the Honeywell controls. They produce a two-channel programmer pack, with two wireless stats. Boiler plus. And no need for internet connections. I've just got to teach the customer to use the programmer (it's easy for me to use, but I might get a few call-backs every time they want to change the times, etc.)
But anyway, what do you reckon of this?
Thanks everyone
Jennie
I'd have put something a bit bigger in. I did a bit of maths. It is a fairly small church, but 30kw only just matches the heat loss / radiator output. So the boiler is working at full pelt a lot of the time.
I would have to check but It probably only does 20kw on heating and 30kw hot water ?
Reply to the thread, titled "Recommendations for Vaillant combi heating controls..." which is posted in Central Heating Forum on Plumbers Forums.
Jennie,
Knappers,
