Have you spoken to the installer, what did they say, was old boiler in same place?
Installer can't see it as an issue. Boiler used to be in kitchen. Boiler was intended to stay in kitchen. New kitchen put in, asked plumber to confirm position was ok, which he did. On day of install was unable to install as he forgot to allow for space around boiler. So he screwed up the new kitchen design.
He suggested putting it in loft above master bedroom. I raised concerns of possible noise. He said it would be fine. It wasn't.
Cost went from £1500ish to around £4-5k as we had to get loft boarded / lightning.
Pretty unhappy with the plumber as with this, he also failed to install a sink properly and caused a leak over new kitchen and floor. I just wanted to pay the plumbers bills and get rid of him. he isn't taking the problem seriously. I know in the grand scheme of things its not such a huge huge issue but after spending £35K on a house renovation and getting everything right, it is tarred by this nuisance noise.
Plumber suggested contacting Worchester, who I have and are coming to take a look, but thought I would ask your advice too.
It's mounted on a breezeblock wall, and it seems pretty tightly mounted. I don't think it's the pipework as this runs through the loft near other rooms and doesnt really cause an issue. The pump is in the boiler.
I'm going to get it boxed in but as the noise can be heard 2 floors down, I suspect the vibration is more the issue. So after Googiling I found anti vibration mounts. Any other advice is very much appreciated.
