Refilling key snapped in open position on Worcester MT10-safe to use?
View the thread, titled "Refilling key snapped in open position on Worcester MT10-safe to use?" which is posted in Central Heating Forum on UK Plumbers Forums.
Hi all,
I wonder if someone can help. We have a Worcester MT10 combi boiler that has a fault with the expansion vessel. The landlord is having the boiler replaced this weekend, but in the meantime I was advised by their plumber to top up the pressure each morning (as it's currently dropping to 0 overnight - it swings up to 3 bar when the heating is on before gradually dropping throughout the day; this is how they've diagnosed it's the Expansion Vessel). Unfortunately, this morning I've gone to do this and now the refilling loop key has snapped off with a bit of the key left in the boiler - the key is stuck in the "open" position (ie where, if I turn the grey knob next to it, it lets in water. I have closed the grey knob, which seems to be working fine).
All I want to know is - is it safe to put the heating on with the key stuck in this position? It's very cold here, and I'd prefer not to have no central heating for 4 - 5 days.
Thanks in advance.
Great - thank you. The letting agent just got back to us and said it should be fine too. I'm presuming the square knob (which is working fine) opens / closes one of the valves?
I highly doubt you have an MT10 boiler, that’s the timer model number. Yes providing it opens and definitely closes, you should be fine.
Reply to the thread, titled "Refilling key snapped in open position on Worcester MT10-safe to use?" which is posted in Central Heating Forum on Plumbers Forums.
celluauto,
celluauto,
