relaxair suction pop up waste
View the thread, titled "relaxair suction pop up waste" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
A
andycolley
Hi I have a rubber seal on the bottom of a suction pop up waste that has perished and most companies say i will have to buy a complete new pop up waste system for approx £115. I only need the bottom seal which will need to fit around a 1" base. Any ideas...Andy
i had that problem exactly last week, went down the storeroom and brought back one of those old time rubber bath plugs, it worked a treat. or you could visit a shed and do what all the other bu***** do and whip one off the display model, or worse from the box on sale, which my customers then go and buy!!!!!!!!!!!!!!!
thanks for the reply, unfortunately the seal is at the bottom of the waste as the bath waste works as a suction above the actual drain if this makes sense!
Reply to the thread, titled "relaxair suction pop up waste" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
andycolley,
andycolley,
