Jun 17, 2022
Essex
DIY or Homeowner
Hi, I'm trying to remove the kitchen tap, it was installed around 2009. I can't seem to unscrew the connector, I've tried a variety of tools from a basin wrench to plumbers grips, access is tight but I can't move it. Can anyone give me any advice? I have called my plumber but he hasn't responded and its been a few days now and my wife wants it done.
Try app some crack it spray, or other form of lubricant and leave it to sit for approx 30 minutes. You could always try to obtain a big box spanner, but if you can get the grips/wide adjustable in, then persevere with it.
Hi all, I tried all sorts of things, from Freeze spray to penetrating oil but couldn't shift the nut. Eventually I applied enough force to remove the entire brass connector from the base of the tap. I then used a dremel to cut the connector. Really annoying and time consuming. I did try to speak to Franke but they were useless.
V
DIY Plumbing Advice
Deleted member 120897
