turbotorch
19
Heating Engineer (Has GSR)
Has anybody ever removed only the bottom part of a cast iron soil stack and somehow supported the rest of the stack and left it in place, or is it only possible to remove the whole thing?
It had originally been outside, but there has been a single storey extension built which the bottom part of the stack is in, it has a concrete ceiling so the stack has been concreted in where it comes through. It goes up through the single storey extension roof then up the outside wall and then through the eaves up through the main roof.
I was hoping for a solution that wouldn't involve removing the whole stack? I was thinking that where it was concreted in might support it, but i think i know what the answers will be here.
Appreciate any help.
Sussex flange, firstly I like your user name, have a look at the thread "Surrey or Essex Flange" post 12 LOL.
As said above is the soil stack fixed to the wall? Most old cast iron stacks have brackets nailed into the wall, if so just cut out a section.
But in an ideal world follow stevetheplumbers advice above and replace the lot in plastic.
Yes of course we have but why do you want to do this ?
Lancashire Flange aka centralheatking
I should have said, i have installed a new stack outside on the side wall so the cast stack is no longer in use. I want to remove the lower part to make way for a kitchen.
BN9Pete quite right! 🙂
In that case remove the lot. Get a nice long ladder and a light lump hammer - bish bash bosh from the top down - bit by bit. Although we have pulled the whole lot down in one go by
attaching chain to stack and landrover and driving off - its good fun. CHK
Reactions: 2 people
Yeah your probably right, although i would be surprised if it moved being concreted in the ceiling, dont want to take the risk though.
Gonna send someone else up up to do it though, dont do ladders..
Make sure to use goggles if using the bish bash bosh method, cast iron in the eye is delightful (NOT)
