Removing warm air unit ductwork
View the thread, titled "Removing warm air unit ductwork" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
K
Kev the gas
Any different ideas/ tools for removing warm air ductwork?
Over the years I have always used crowbars/ hammers drills for the rivets ect. Is there a magic tool/cutter that is worth having?
Anyone ?
The buggers down here didn't use screws, only rivets and tape that is still as strong if not stronger 30 years later, and then there is the 2 inch ribbed nails they used at the outlets, into the frame work.
Was thinking of a nibbler? Like the sunroof fitters used to use
I have the recip saws, 240 v and bosch 10.8v.
The hackzall blades seem hard to find on the net, I normally use the makita/ bosch blades. I have the milwaukee demolition blades.
I just use the cheap blue ones at poo fix they are identical to Bosch. Recip comes from toolmonkey it's 18 v tho.
Tool Monkey Ltd
Building Materials Supplier
Clipstone Brook Industrial Estate, Cherrycourt Way, Leighton Buzzard LU7 4GP
01525 374287
£129 bare delivered next day
Reply to the thread, titled "Removing warm air unit ductwork" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Kev the gas,
kris,
