Repair on buderus 500 combi
View the thread, titled "Repair on buderus 500 combi" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Leezygeezer
Hi guys
i have a leak on above boiler, coming from the 2 brass nipples cold and hot, from the abs plastic heat exchanger connector. Made an initial attempt to remove the plate as not sure if it's the 2 nipples leaking or the plate, it's an absolute pig. Anyone know the best way to remove this? Tried from the top but stopped short of stripping everything out it!
thanks
Reply to the thread, titled "Repair on buderus 500 combi" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Leezygeezer,
Leezygeezer,
