View the thread, titled "repairing a redfyre back boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi
I am trying to fix an old redfyre back boiler which has been leaking through the gasket. I have a new gasket but two
Of the bolts holding the backplate and gasket in place have rusted off. Does anyone know if you can get new bolts
Or do you need a completely new back boiler. I enclose some pictures which I hope will help
Hi Paul
its not obvious from your profile but are you GSR.
I suspect not and as such you probably won't be able to get an answer here.
Hi Paul
Hi Riley
Yes you are right. I am not a GSR plumber but this is not a gas boiler but a solid fuel wood boiler. Maybe I am on the wrong forum and should be on solid fuel?
Paul
You'd need to carefully drill out the broken bolts and re-thread the holes.
If you've never done that, 1st attempt on a boiler is the wrong place to start.
The are mobile specialists that do this for cars, try one of those, certainly cheaper than a new boiler.
If bolts are rusting off, is it not about time to bite the bullet and put something more up to date in?
Reply to the thread, titled "repairing a redfyre back boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
