F
fdwhite
I'm planning to revamp our bathroom as my better half would like a "hotel" style bathroom with tiled floor & walls, heated mirror & underfloor heating😱
Its the underfloor heating that I need some help & advice on as I would like to replace the present radiator with water UFH that will run off of the combi boiler & be a direct replacement for the rad. Is this possible?
The present bathroom rad doesn't have a thermostatic valve as its the boiler heatsink, so the UFH would have to be the same.
I'm thinking of replacing the floorboards with a sheet material (chipboard, MDF or similar) thats going to be thinner than the boards in order to create as small a step as possible when entering the bathroom.
Any thoughts on clipping the UFH pipes to the joists instead of running on top? Again to keep the overall thickness to a minimum.
Any help gratefully received.
