View the thread, titled "replace old Honeywell T40 stat with Wireless DT92E" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
adriaan029
Please can someone give me some advice
I want to change the old fixed stat with the Honey BDR91 Relay Box so I can have wireless
just not sure on connection
I am using a two way multi zone system
Old stat
Earth
Blue wire in 2 / yellow wire in 3 / Red wire in 1
New Relay Box
Do i put Blue wire in N
Yellow in B
Red in L
any help much appreciated
Nope, will need the relay box in the wiring center as it requires permanat L and N plus 2 wires to switch through.
Not sure what you mean, reading from other people, it's pretty straight forward, using existing wires
four wires one is N one is L one is needed for the switchable which is yellow
it is simple you just need 4 cores to the reciever box, permanat live and nuetral, switched live in from the programer and switched live out to the control valve.
Has I want to use the box where the stat was, does that mean I can use the earth cable has one of the thanks for your help
No earth cable isn't suitable, you need to put the box by the wiring centre (in the airing cubard normally) and disconect existing room stat, then wire up from there, if you're not sure then best getting some on in.
Reply to the thread, titled "replace old Honeywell T40 stat with Wireless DT92E" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
adriaan029,
Roger Welton,
