A
aetius80
I have a ferroli falcon that is broken, I've repalced both circuit boards, spent hours doing diagnostics, but I still can't fix it. I'd like to buy a replacement boiler, but want to make as little alterations as possible - boiler is in a bathroom cupboard and access is tight, so I want to avoid drilling holes for a new flue, brick work, etc. If I could, I'd buy another ferroli falcon and simply do a switch over, but the boiler is no longer available.
Can someone recommend a suitable replacement for a ferroli falcon? I have a 2 bedroom ground floor flat with 5 radiators and am looking at spending around 500-750 for a new boiler.
I've also heard that boilers with a power rating of 24KW give barely lukewarm water and I should be looking at a 28KW or higher boiler.
Please advise.
Please advise.
