View the thread, titled "Replacement fitting for heating oil fuel supply" which is posted in Boiler Advice Forum on UK Plumbers Forums.
View attachment 42552 I need to replace this fitting that is connected to the heating oil fuel supply to my boiler, can anyone recommend a supplier and also what what is this component known as, so that I order the correct part. TIA
That's a remote sensing fire valve. A phial hangs over the burner with a capillary tube running back to the valve, when the set temperature is sensed it automatically shuts the valve and cuts off fuel supply. I would fit a Teddington KBB 65°c but you need an oil engineer, you should not try this yourself.
Reply to the thread, titled "Replacement fitting for heating oil fuel supply" which is posted in Boiler Advice Forum on Electricians Forums.
