J
johnsculp
Hello.
Have a small cottage that had electrics rads in. I want to get a wet central heating system put in. The hot water for the cottage comes via a heating element in the cylinder and the occasional use of a wood burning stove which is plumbed in to heat water as an alternative.
Can this existing cylinder be used in the new CH system? Could the wood stove be disconnected and the cylinder hot water heated via the new CH but not having top take the original tank and expansion tanks etc, out? The system at the moment is all gravity fed. The new central heating will either be oil or biomass.
