View the thread, titled "Replacing a low level cistern for close coupled" which is posted in UK Plumbers Forums on UK Plumbers Forums.
PriestyUK
Anyone come across a close coupled toilet that gets you over this problem yet,? without having to pull up the floor and relocate the soil pipe or build a pointless boxings behind the toilet. In this case I want to be able to get the pan as far back as poss.
PS If anyone wants the pink pan and pink pedestal basin its yours 😀 once i've removed it of course (One old lady owner, high mileage though lol)
Cheers guys
PriestyUK
I doubt you'll get one to accommodate that but worth popping into your merchant with the measurements to see what they can come up with.
I normally quote a like for like replacement in this situation ! Close coupled stuff is over rated anyway! Looks awful with that 4 inch batten behind loo too
I have one of these to do this weekend for a cousin floor up fernco on bit of 110 and a rest bend if I can get it in if not a elbow and re concrete lasttime I did one it took about 3 hours to break out and get all pipework done and another hour to concrete in but then its time to call it a day till the gobo goes off then refit toilet next day
Found one that I think is going to work, will leave me with only a 30mm gap which I dont think will be that bad. What you think guys?
[DLMURL="http://www.uk.roca.com/wps/portal/EI004/catalog-product-detail?codeProduct=34251S..0&codeDL=066-14.0087"]Roca[/DLMURL]
Dimensions: http://www.uk.roca.com/RocaResource...Object={50135B4D-3302-478C-9D47-20D97602B724}
I currently have 245mm from wall to centre of soil pipe. I also like the pan connector kit that also stops it blowing off the back of the pan 😀
a 30mm gap at the back wont look bad at all personally I would cut 2 pieces of 15mm chrome to use as spacers and screw straight through the centre of them providing the loo is drilled for cistern fixings, I prefer 2 pieces of chrome pipe rather using timber or tiles personally I think it looks tidier but everyone has there own way and after all the customer is the one who has to see it everyday so its them that has to be happy with it
Reply to the thread, titled "Replacing a low level cistern for close coupled" which is posted in UK Plumbers Forums on Electricians Forums.
