batfinki
Hi all
I wondered if someone could give me a bit of advice.
I have a Back Boiler that has been condemned as it is leaking fumes which aren't all being expelled up the flue and so need to replace it with a Combi boiler. The Back Boiler is of course located behind the fireplace in the living room.
The property is a 3 bedroom semi with no more than 6 radiators and a towel rail.
Directly above the fireplace is the 2nd bedroom with the water tank in a large airing cupboard. I'd expect the water tank to be taken out and the new Combi boiler to go in there. The gas feed will need to be extended from the back boiler straight up into the cupboard above.
As I understand it with current regulations the radiators will need to have thermostatic valves fitted and the rooms need thermostats too. I presume the radiators don't need to be replaced.
I believe the loft tanks and the hot water tank will need to be disposed of. The Back boiler too. In the short term I intend on leaving the fire in place just for show.
I'm thinking of a Baxi Duo-tec Combi HE A as it has a 7 year warranty and appears reasonable value around £800.
Can anyone give me an idea of how much would be a decent quote for this job? I don't know a lot about the subject so I've pieced together research, plumber's advice and general heresay so please feel free to correct anything I've said.
Thanks very much
Steven
Thanks very much
Steven
