View the thread, titled "Replacing combination valve megaflo" which is posted in Central Heating Forum on UK Plumbers Forums.
If its an exact part swap with no pipework needed to be altered I will be honest it does sound enough
Obviously depends on the part then vat etc , if the valve isnt above the cylinder it is a bigger job .
If it’s quite old, the valve has changed so will need pipework tweaking. If valve is above tank - that sounds a bit steep for round here but it depends where you are in the country.
Reply to the thread, titled "Replacing combination valve megaflo" which is posted in Central Heating Forum on Electricians Forums.
