View the thread, titled "Replacing Honeywell thermostat with nest?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all, just after some advice I’m looking to replace my current thermostat with a nest system. It states that’s it’s compatible however wanted to check before purchasing and installing. My thermostat has 3 wires as shown in picture. Any help would be appreciated. Thanks
Yea literally just the manual thermostat. That’s why I wanted to change it to the nest one so I can set it up to come on at certain times etc just wasn’t sure it I can simply remove the old one and connect the new one with the wires that were there.
You should be fine then just hope there’s an earth connection / wire at the back of the thermostat
Don’t think looking at it I can fit the nest as it’s 230v and nest requires 12v. This would just blow the nest I believe.
The receiver would go where the existing thermostat is
If you want the nest unit there you need the services of a gas safe engy to wire it up
Reply to the thread, titled "Replacing Honeywell thermostat with nest?" which is posted in UK Plumbers Forums on Plumbers Forums.
