View the thread, titled "Replacing mixer shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
J
johnaaronrose
Currently I have a not-working-properly Mira Combiforce 415 mixer shower. The back-inlet water pipes project 13mm beyond the tiled surface. Each pipe is within a 32mm diameter x 10mm deep recess. The mixer shower unit is connected to the pipes by 1/2" BSP Male compression fittings. Hopefully, I should be able to remove this (including the olives) without removing the tiles (which are on plasterboard), as I have no spare matching tiles. I would like to replace it with a bar valve thermostatic shower e.g. Mira Coda EV. The instructions for this shower state that it should be connected to a 1/2" Female BSP and it looks like it's below the surface (though there's no statement of how much) so that the Mira offset connector projects 35-40 mm above the surface. is it feasible to carry out this job without removing tiles.
Regards,
John
Reply to the thread, titled "Replacing mixer shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
