Replacing motorised valve steps
View the thread, titled "Replacing motorised valve steps" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi Folks,
Please advise as i wish to change a motorised valve connected to a heat only gas boiler:
Turn off the boiler
Turn off the mains water
Find a draining point and drain system
Replace motorised valve
Make sure draining point is closed.
Turn on mains.
Turn on boiler.
Bleed the radiators.
Job done?
Don’t know if these pics are of any use to you.
How to take apart a valve, I did for someone a while ago.
Complete valve
Cover removed
Two screws you need to remove
Pull head off
Body
Reply to the thread, titled "Replacing motorised valve steps" which is posted in UK Plumbers Forums on Plumbers Forums.
allysunlife,
Timmy D,
