Guest viewing limit reached
Replacing Programmer
View the thread, titled "Replacing Programmer" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi Guys,
I currently have a British Gas UP2 programmer and have been thinking for some time about replacing it with one that will allow me to program the central heating and hot water to come on at different times to each other as well as having different times for different days.
Is it just a case of getting a new programmer that does this and then swapping it over with the old one, ensuring the wires all go to the right terminals or is there a lot more involved?
Many thanks,
Carl.
A UP2 is a rebranded Drayton LP722. It allows full independent setting of water and heating.
If you have a mid position valve and can't get independent control, it is wired wrong.
I can make the heating and hot water come on independently manually for example using the advance button on whichever one I want on, but there is no option to program them independently of each other, in that aspect its all or nothing!
[DLMURL]http://www.draytoncontrols.co.uk/WorkArea/DownloadAsset.aspx?id=28346[/DLMURL]
Have a read.
There are switches on the back of the programmer I think to switch between independent timing or both together.
Thats true some do some don't. I forgot about that.
If you look on the back there will be 3 sets of jumpers
The top one sets independant control.
Ok, I have the timer off now, so I'm presuming that the middle jumper that is labelled either "1" or "7" which is currently set to "1" should be on 7 as well?
the 1 and 7 is if you want 7 days all with the same timings leave on 1 or 5 days the same and 2 days i.e. week and weekend then put it on 7
Whatever you like.
They are actually a very good reliable programmer.
Sorry for hijacking a thread. But I just wondered what the different "jumpers" are for. Obviously the 1 and 7 jumper is for the 7 day programming. I am guessing the P and G jumper is for pump or Gravity fed. But what is the L jumper for?
Many thanks
Hi Ads,
Not sure what the L stands for, maybe linked?
But basically, it sets whether you can program the heating and hot water to come on at different times to each other or not.
Carlos.
Hi Ads,
Carlos.
Thanks, I'll leave well alone, but just wondered.
cheers
Hi
when I have my hot water on the heating comes on.
This has only just happened.
I have a mid position valve would this be stuck or broken and need replacing?
You should have probably started a new thread mate, as more people may comment on it. Sounds like the 3 port is stuck or damaged. Can you post a picture of it, and we may be able to advise more?
Some valves you can remove the actuator head and free the spindle to move fully, but if the pendulum ball (only way I can describe it) inside is damaged, then you will need a new valve.
I have a salus single/two channel programmer put the heating on manually yesterday for two hours .It came on for the two hours but when it went off it did not come on again looks as if the programmer has no power will not switch on
Hi Catherine, wouldn`t be powered by a battery would it?
Really need you to register and start your own thread that way your liable to get a better response.
Reply to the thread, titled "Replacing Programmer" which is posted in UK Plumbers Forums on Plumbers Forums.
Carlos_UK,
Dotty,
