R
rossm
Hello,
Posting for the first time to get some advice on replacing an oil-fired boiler (Trianco Eurostar 110 STD - states 110 BTU/hr or 32KW). This boiler is being kept alive with parts & regular fettling & has eaten up a set of baffles, 2 transformers, 2 photocells, 4 nozzles, an oil pump, 2 solenoids, a set of spark contacts and a control box since we moved in 7 years ago and is running so inefficiently that it seems to fire more or less continuously when the heating is on. Space for its replacement is not a problem as this boiler sits in the laundry/utility room of an old, stone built, large & rambling farmhouse (16 radiators) but efficiency is, hence the questions I wanted to get more knowledgable opinions on.
I think there are 4 specific questions I'm needing to work out answers to :-
1. Am I right in thinking that I am risking revealing / creating weaknesses in the pipework by moving to a combi system ? Our house water supply pressure can be wound up pretty high via the external cock so could quite likely supply enough head to drive it. Not that hot running water is much of an issue (see below).
2. Would any boiler models allow us to heat water for radiators only i.e. isolate 'off' the hot water to the tank ? We rarely use hot water as we have electric shower & never use a bath.
3. Is there any big efficiency downside to overspecifying the heat output of the boiler i.e. in the Worcester Bosch Greenstar range, I guess the 25/32 might be sufficient but would the 32/50 be capable of running as efficiently ?
4. What are the upsides or downsides to going with an external boiler ?
Really appreciate any thoughts & thanks
Ross
Ross
