View the thread, titled "replacing washer on toilet inlet valve" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I have an inlet valve that is allowing some water in even when the float is raised. I wanted to check the washer - presumably diaphragm, but after taking off the cap, I'm unsure how to dismantle the valve. Any tips?
The inlet came with a NUCA C211 valve.
The other option is to remove/replace the inlet, but I'd hoped a washer would do the trick (less waste, easier!)
Have to turn the handle part anti-clockwise with the water off to the Cistern and hold the bottom body
Do they tend to rotate either way, or only one way (anti clockwise). No space to twist anti clockwise due to location in the cistern (otherwise it will be time to totally remove)?
Reply to the thread, titled "replacing washer on toilet inlet valve" which is posted in Boiler Advice Forum on Electricians Forums.
